dwally
Jan 06, 2021Aspirant
How to get iphone to select strongest signal when using EX5000 Extender
I recently added a Netgear AC1200 WIFI Range Extender to my network (WNDR3400v2). Unfortunately it does not appear that my Apple devices (iphone 11, Ipad, macbook) will automatically move to the str...
dwally
Jan 09, 2021Aspirant
Connecting to the network is not the issue. However if I’m working on the second floor of my home, I want to connect to the Extended signal, because it’s strongest. But if I move to the lower level where my main router is located, I’d rather use the main network versus the extended signal, since the main is stronger on that level. I’m trying to determine if that can be done automatically without having to change to the other network manually. Thanks.
olympos1625
Jan 12, 2021NETGEAR Employee Retired
Hi dwally,
Thank you for your response. Yes, that is possible if your extender has Mesh capability. What is the exact model of your extender?
Please do not hesitate to let me know if you need further assistance.
Oliver
Community Team
- dwallyJan 12, 2021AspirantIt’s the EX5000. I’m guessing it’s not mesh capable, but really not sure.
- olympos1625Jan 12, 2021NETGEAR Employee Retired
Hi dwally,
You are correct. The Netgear EX5000 is not a Mesh extender therefore it uses the traditional extender method.
https://www.netgear.com/home/wifi/range-extenders/extenders
Oliver
Community Team
