BrandoManfredi2's avatar
Dec 21, 2020
How to improve my home wifi network
Good morning everybody,
I would like to know if my old modem router D6200 can be extended by connecting two wifi extenders to my home network.
Right now I have just one EX6150 working as wifi extender but, I still have some corners in the house not covered properly.
Would you think another EX6150 or EX6130 could solve the problem?
Can my existing D6200 handle two devices?
I know that I could buy something more expensive like Orbit and move to step 6 but, so far, my network is working fine and D6200 working as a router linked to an optic fiber access point is performing well. We are six persons in the house and each one has his/her own PC and smartphone and the system cope without problem
Thanks in advance for all your help
  • plemans's avatar
    Dec 21, 2020
    You're caught in a catch22. Brick blocks wifi really well. Which causes issues with extenders AND wireless mesh systems.
    the best option? Bite the bullet and run ethernet or use coax MoCa adapters.
  • plemans's avatar
    Can you have 2 extenders? Sure, but you need to make sure to set them right.
    Don't daisy chain them. Set them up in a star configuration
    Star:   Extender<-------router------->extender
    Daisy chain: router------>Extender----->extender
    Reason why is if you daisy chain, that final one will only run at 25% speed and have much higher latency.
    • Thanks for the reply. I fully agree with you. Each extender must be connected with the router; no daisy chain.
      This means D6200 can handle two extenders; am I right? of course when properly connected.
      • plemans's avatar
        It should be able to.
        I'm not a fan of using more than 1 extender but it does work and I've done it.
        I usually tell people to avoid the hassle of having that many ssids and just going with a mesh system but the choice is yours
