vijay_amrit's avatar
Dec 01, 2020
How to login to modem router configured to run as modem only
Hi,
I have a C3000 modem + router which i was using as modem only for sometime. Now i want to enable its router function and i connected my laptop using a LAN cable. I am able to access internet,  however i am not able to login to the modem. tried routerlogin.com, routerlogin.net, 192.168.1.0, 192.168.1.1, 192.168.0.1 etc but the page wont load. How does one configure a modem only?
Vijay
    • vijay_amrit's avatar
      vijay_amrit
      Tutor
      Thanks. was able to login and configure the router. However realized why I had disabled it straight away. Speed over wifi drops few mins after router startup.
      • plemans's avatar
        Yeah, 2.4ghz is a slow band and sensitive to interference. If you're streaming/gaming/doing anything needing bandwidth, dual band is a must.
