Jno2
Jul 09, 2020Tutor
How to manage my R6400 router from PC. I don't want Nitehawk App on my phone.
How do I manage my R6400 router from PC. It used to be routerlogin.net, but no longer...
I do not want the Nitehawk App on my (old) phone.
What do I do?
Thank you.
if you're on windows
open a command prompt (click on start and type cmd)
type ipconfig and hit enter.
the default gateway address should be your routers address. This isn't always the case if you're in a double nat situation.
You can log into it using the ip address of your router.
That's all I use for accessing mine.
- Jno2Tutor
It was suggested I long in with the IP address of the router. How do I find that?
(using a PC)- plemansGuru - Experienced User
