molatech
Jan 07, 2017Tutor
How to set time of day
I think I know the answer. Sort of. It can't be. But I've never had a router where one could not set the date and time or at least pick a time zone so the router would have the correct local time. Go...
- Jan 08, 2017
Thank you for the reply.
After looking through the entire R6400 manual, I saw under Supplemental Information and Factory Settings that there was a listing under Local Network settings for Time Zone and Daylight saving time. Table 3 lists the 'default settings'. So thinking that since there were default settings, they must be user adjustable somehow.
Seeing this under LAN settings..I went through every menu in the Genie software interface and FINALLY found this setting under Security... and then Schedule.
At bottom of Security:Schedule page I was able to set the time zone to mine and it subsequently corrected all the log entires and current date and time correctly.
KInd of an obscure place for simply setting the time, but I hope this helps anyone trying to find this setting.
michaelkenward
Jan 08, 2017Guru - Experienced User
What hardware are we talking about here? R6050?
If so, look at page 129/130 of the manual:
R6050 | Product | Support | NETGEAR
molatech
Jan 08, 2017Tutor
- michaelkenwardJan 08, 2017Guru - Experienced User
It took me a few seconds to search the PDF file of the manual for "time zone".
I agree that it is well hidden.
