mikeshick's avatar
mikeshick
How to set up lan-lan cascade with Netgear R6300v2
I'm unclear how to set up lan-lan cascade with Netgear R6300v2.  I have tried to leave internet as select automatically, and then changed the lan to be 192.168.0.2, while my main router, and therefore gateway is set to 192.168.0.1.  When I set this up, I can connect from computer to router, but not main router lan to Netgear R6300v2 lan.
I see this article on wireless ap mode, but I want both lan and wireless, i think.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode-after-setting-it-up
  • plemans's avatar
    both lan and wireless work in AP  mode.
    • mikeshick's avatar
      mikeshick
      So, my steps are:
      change the lan ip address as mentioned
      turn off dhcp server
      turn on wireless ap?
      Do I need to have the same wireless broadcasts and/or passwords?
      Is there any problem connnecting this to UDM as main router?
      Thank.
      • plemans's avatar
        Turning on AP  mode, disables the dhcp server.
        You can set them with the same ssid/password as the primary router but it won't be a seamless setup. Devices will tend to be sticky and stay connected to the wireless they initially connected to until it drops/becomes unusable.
        I prefer to use different ssids in this instance.
