IAmAshok's avatar
IAmAshok
How to use Netgear AC1200 R6120 Router as Repeater without ethernet cable?
Hi Guys,
I recently bought Netgear AC1200 R6120 dual band router and want to use it as a range extender/repeater , has somebody done this? I have searched everywhere and was not able to find any solution. I do not have ADVANCED > Wireless Repeating Function in my advanced setup. I only see make router as Access point with wired connection. Is there a way to do it as repeater/range extender with wired connection?
Thanks in advance.
Cheers!
  • > [...] I only see make router as Access point with wired connection. Is
       Huh?  Do you want a wired or wireless connection to the
    repeater/range-extender/access-point?  As its User Manual suggests, a
    wired connection to an R6120-as-wireless-access-point may be all you can
    do with an R6120.
