jjhaigh
Jul 12, 2016Aspirant
HTTPReadySHARE cannot be opened because of a problem
Hi everyone
How the heck do I get rid of this annoying piece of software (which I don't even use!!) from my iMac, which generates an error message roughly once an hour saying that HTTPReadySHARE cannot be opened "because of a problem" (not a particularly helpful message)? There is almost no helpful information online. I’ve tried to rm the file HTTPReadySHARE using Terminal but the system won’t let me; I’ve deleted the relevant .plist file from the LaunchAgents directory and I’m no longer using the Netgear Router (WNR2200) that set up the process. I cannot find any other files with the same name or Netgear in them anywhere on my machine. I’m now at a loss and don’t have the technical expertise to try anything deeper.
I'd really appreciate any suggestions!
Many thanks,
Jonathan Haigh
Here's what comes up in the error message detail......
Process: HTTPReadySHARE [24936]
Path: /usr/local/httpreadyshare/HTTPReadySHARE
Identifier: HTTPReadySHARE
Version: ???
Code Type: X86-64 (Native)
Parent Process: launchd [183]
Responsible: HTTPReadySHARE [24936]
User ID: 501
Date/Time: 2016-07-12 12:10:51.090 +0100
OS Version: Mac OS X 10.9.5 (13F1808)
Report Version: 11
Anonymous UUID: 63F90677-DFE7-FA5F-AE3B-C9826D14BC56
Sleep/Wake UUID: CA338A6B-E042-4BB9-8D35-D59D60EECB01
Crashed Thread: 0
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: libboost_system.dylib
Referenced from: /usr/local/httpreadyshare/HTTPReadySHARE
Reason: image not found
Binary Images:
0x7fff672be000 - 0x7fff672f1887 dyld (239.5) <1D3130FE-FE7E-3C4C-8E74-EB51895B6BA5> /usr/lib/dyld
Model: iMac9,1, BootROM IM91.008D.B08, 2 processors, Intel Core 2 Duo, 2.66 GHz, 8 GB, SMC 1.36f3
Graphics: NVIDIA GeForce 9400, NVIDIA GeForce 9400, PCI, 256 MB
Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1067 MHz, 0x859B, 0x435435313236344243313036372E4D313646
Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1067 MHz, 0x859B, 0x435435313236344243313036372E4D313646
AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x8E), Broadcom BCM43xx 1.0 (5.106.98.100.22)
Bluetooth: Version 5.2.7f4 15858, 3 services, 23 devices, 1 incoming serial ports
Network Service: AirPort, AirPort, en1
Serial ATA Device: WDC WD3200AAJS-40H3A0, 320.07 GB
Serial ATA Device: OPTIARC DVD RW AD-5670S
USB Device: MG7700 series
USB Device: Built-in iSight
USB Device: Elements 1042
USB Device: Keyboard Hub
USB Device: Apple Keyboard
USB Device: CTH-470
USB Device: BRCM2046 Hub
USB Device: Bluetooth USB Host Controller
USB Device: IR Receiver
FireWire Device: Rugged USB3-FW, LaCie, Up to 800 Mb/sec
Thunderbolt Bus:
We have officially released the compatible software to work with Mac OSX and above.
- ElaineMNETGEAR Employee Retired
By the way, have you tried reinstalling and then removing it again?
- wood92Aspirant
I have same issue. I still use my Netgear WNDR 4500 router and it works fine but a year or so ago these same warnings started popping up on my computer. I uninstalled my Readyshare app and don't really have a need to reinstall it as I don't use a ReadySHARE printer or attached USB devices. Has anyone found any answers other than a reinstall to make this go away.
Also, the ReadySHARE Printer download says it only supports MAC OS 10.9 but I'm on 10.11.6. Would it be a waste of my time to reinstall?
wood92 The USB Control Center Utility is not available yet to work with the El Capitan and newer Mac OS.
You may want to see the thread from apple regarding the error.
https://discussions.apple.com/thread/4207127?start=0&tstart=0
