JohnstonJacob88's avatar
Jan 31, 2023
Hulu/Disney+ not working on Nighthawk R6400v2
Hello! A few weeks ago I transferred my spectrum Wifi network from my roommates name into mine (using the same router and modem as before) and now disney+ and Hulu both won’t work on ANY device connected to my home wifi. I have already been through customer support with both spectrum and Hulu and they both said to contact my router people. Any ideas?
  • plemans's avatar
    Feb 01, 2023
    Either way, glad its working!
    Should mark it solved so others aren't still trying to fix it still 🙂
  • plemans's avatar
    What error does it give you?
    When you switched services, did you factory reset and start over?
    Have you tried changing dns providers?
    Try a different DNS Server. Here's a few for ipv4. Also remember to change the ipv6 dns server if ipv6 is enabled
    CloudFlare 1.1.1.1 and 1.0.0.1
    GoogleDNS 8.8.8.8 and 8.8.4.4
    • Hulu gives me P-dev313 on my TV and P-dev314 on my phone. Disney just says it can’t be accessed but I’m more so concerned with Hulu. How do I change DNS? Thank you!
      • plemans's avatar
        what modem/gateway is the router connected to?
        What speeds are you paying for?
        What device is it thats having issues?
