broman42
Nov 16, 2020Follower
I can not find my WIFI Name
I can not find my wifi network when trying to conect my tv to the wifi.
> Model: C6300|AC1750 Cable Modem Router Docsis 3.0
C6300[v1] or C6300v2? Look for "Model" on the product label.
> I can not find my wifi network [...]
Which one? A C6300[vX] is a dual-band router, so it could have two
SSIDs.> [...] when trying to conect my tv to the wifi.
"my tv" is not a very detailed description of anything.
Do other wireless devices work as expected with your C6300[vX]? Does
your (unspecified) "my tv" find other wireless-network signals?Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual (at least). Read.
Look for the LED descriptions and "Troubleshoot". Pay particular
attention to the "WiFi On/Off button". Did you press it? Further
reading might not hurt, either.- michaelkenwardGuru - Experienced User
Are you using the TV's set up routine to connect?
Can other devices find the wifi?
What is this TV?
By the way, a wired connection is usually best. Wifi can be hard to set up on many TVs and often unreliable.
If you can't plug the TV into the router, then Powerline Ethernet can be a great alternative.
