Mph3842's avatar
Mph3842
I have an R6400 and want to connect a HDD via USB as a NAS drive
I have a Nighthawk R6400 router and have a HDD connected to it via its USB port. I want to set up Readycloud but cannot seem to do it. Advice please?
    • Mph3842's avatar
      Mph3842
      Thanks for your reply.  When I look at the Netgear Router page, under Readyshare, the Readycloud button does not appear (see photo). The USB drive I have connected is an 8TB Seagate Hub Plus.
      • michaelkenward's avatar
        michaelkenward
        Readyshare is very picky about the USB drives it will accept. 8TB is too big for most devices. The limit seems to be about 4TB.
        This list will give you some clues, although it is far from comprehensive:
        ReadySHARE USB Drives Compatibility List | Answer | NETGEAR Support
        Your subject says "want to connect a HDD via USB as a NAS drive". By convention NAS usually means Ethernet. That's not USB.
