Rub-lin's avatar
Rub-lin
I replaced my spectrum modem with netgear cm1000v2 but I am not getting the speed that I used to.
Netgear cm1000v2
I can't get the speed that I used to. It was more than 300mbps and now it's only 70 mbps max.
  • are you hardwired into the modem with a pc/laptop?
    how are you testing?
    Do you have a screen snip of the cable connections page and the logs?
      • plemans's avatar
        Guru
        That doesn't tell you how the modem is performing as its using the wireless of the router (which could be the issue).
        Hardwire a pc/laptop into the modem, reboot the modem, and then test the speed on it.
        That'll tell us the speed you're getting from the modem.
