Retired_Member
Dec 08, 2016I would like to install VyprVPN onto my R6300 v1 router.
I would like to install VyprVPN onto my R6300 v1 router. GoldenFrog support has a how to page to do this but it says: 2. Log into the router firmware and click Tools. 3. Click System Commands in t...
- Retired_MemberDec 16, 2016
Thanks, that is what I thought :mansad:
Not sure I want to go with third party firmware
Thanks again to all,
Jim
netwrks
Dec 08, 2016Master
Correct - there is no way to add the VPN software to the stock firmware. Search for 3rd party firmware to run on the R6300.
Jim
- dyingjediJan 10, 2018Aspirant
Which third party firm did you go with that acuallty worked? thanks id like to do the same.
i have lifetime VPN's want to utilize for all router trafic.
