ToddeSwe's avatar
Aug 03, 2015
Icy Box IB-RD3620SU3 does not work with WNDR-3700 v2?!
Hi
Have attached my new Icy Box today but my WNDR-3700 v2 does not recignize it. Why is that? I have one WD 4 TB Red series NAS drive inside.
Nothing happens, i have restarted it, the computer.. what to do?
Torbjörn
  • Hi
    I got an answer from the manufactor of Icy Box and they told me that it can't be connected to anything else than a PC or Mac since it needs some drivers or software to operate.
    Thanks for you reply though
    Torbjörn
  • ElaineM's avatar
    ElaineM
    NETGEAR Employee Retired
    Hi ToddeSwe,
    Welcome to the community!
    You may want to try using a different HDD or a thumb drive to be connected to the WNDR3700v2. What's the firmware installed on your router? Do you get a led light on when you connect your Icy Box to the router? Check also this known compatibility list.
    • ToddeSwe's avatar
      ToddeSwe
      Guide
      Hi
      Torbjörn
      • ElaineM's avatar
        ElaineM
        ToddeSwe Thank you for that update! This information will surely help others.
        Have a great day!
