Swapnil_1989
Feb 20, 2017Aspirant
Inconsistency observed in information provided for Netgear router WNDR3400 on Netgear webpage,
I wanted to buy a budget wifi router,while searching on internet i came across Netgear WNDR3400 router. When i saw USB port support is also provided i decided to buy the product but the USB port disp...
- Mar 05, 2017Hi ElaineM as it was as major issue which I found out can I expect a compensation (gift) for the same ?
As it was a defect which your QA team forgot to identify.
Swapnil_1989
Feb 21, 2017Aspirant
But on each and every online shopping sites also it's showing blue USB port image of router which directly says the perticular model supports USB 3.0
William10a
Feb 21, 2017Master
Most of the people who write the information on their web sites never lived through the changes of the serial port into the usb1 then2 now 3.0 and 3.1 even being replaced now on paper by faster standards and just repeat a scape. Color means little when yellow is ground and black is signal line by some wiring codes .
