Swapnil_1989
Feb 20, 2017Aspirant
Inconsistency observed in information provided for Netgear router WNDR3400 on Netgear webpage,
I wanted to buy a budget wifi router,while searching on internet i came across Netgear WNDR3400 router. When i saw USB port support is also provided i decided to buy the product but the USB port disp...
- Mar 05, 2017Hi ElaineM as it was as major issue which I found out can I expect a compensation (gift) for the same ?
As it was a defect which your QA team forgot to identify.
Swapnil_1989
Feb 21, 2017Aspirant
USB 2 port is in black color right ?? And to show if USB port is 3.0 blue color is used right ?? Then why in netgear webpage the router is displayed with blue color port . I know it has 2.0 USB port . But then in image also they should display black port only saying it's 2.0 USB.
For a new person it's hard to get as after seeing blue port he will think it's usb3 port and after purchasing router he will think he is cheated .
Even on many website ur router image is displayed with blue color USB port instead of black.
- William10aFeb 21, 2017Master
I have seen the pictures you were looking at the wndr3400v1 even has a blue usb port. What do you need the router to do?
The color blue even has a value of 6 on the color code chart for resistors so it is all in how you look at it.
