Swapnil_1989
Feb 20, 2017Aspirant
Inconsistency observed in information provided for Netgear router WNDR3400 on Netgear webpage,
I wanted to buy a budget wifi router,while searching on internet i came across Netgear WNDR3400 router. When i saw USB port support is also provided i decided to buy the product but the USB port disp...
- Mar 05, 2017Hi ElaineM as it was as major issue which I found out can I expect a compensation (gift) for the same ?
As it was a defect which your QA team forgot to identify.
Swapnil_1989
Feb 21, 2017Aspirant
See basically my question is that why blue color port is displayed for USB 2.0 port. And now we have standards for USB port color code then netgear should update the images of router on webpage to avoide such confusion . I have not purchased this router till now . But netgear should update the images on netgear site too .
If the product getting delivered to customer is black USB port then on webpage it should display black only not blue . Blue USB port says it's USB 3.0 port
