Swapnil_1989
Feb 20, 2017Aspirant
Inconsistency observed in information provided for Netgear router WNDR3400 on Netgear webpage,
I wanted to buy a budget wifi router,while searching on internet i came across Netgear WNDR3400 router. When i saw USB port support is also provided i decided to buy the product but the USB port disp...
- Mar 05, 2017Hi ElaineM as it was as major issue which I found out can I expect a compensation (gift) for the same ?
As it was a defect which your QA team forgot to identify.
schumaku
Feb 23, 2017Guru - Experienced User
Why? Because there is nothing wrong. Completely legal, completely correct. Matter of fact many vendors (even the SoC makers sample boards) used the blue ones.
Still, the fact that you think blue is USB 3.0 is wrong. Only the specs are relevant. Nobody will update pictures in this consumer class market. Even less, no reseller or retailer will update his online offering.
Years ago, a NAS vendor has introduced an "updated" Mk.II or "plus" model of an existing product - along with a newer SoC two of the four USB ports were updated to USB 3.0. The marketing images remained the same.
It's a budget box. The performance of the processor is much to limited anyway to make use of the USB 3.0 bandwidth - there would not be any advantage. Buy it, or leave it.
