azcowboy's avatar
azcowboy
Increase Ethernet Output speed on Netgear R6220 router
I am having trouble obtaining the same (or nearly the same) ethernet output speed from my router as I obtain directly from my modem.   I have tested my Cisco Modem (using speakeasy) wired directly ...
  • azcowboy's avatar
    azcowboy
    Apr 23, 2016
    I replaced the CAT5 and CAT5E cables with CAT6a (Shielded Twisted pair) and my problem is solved.  Spedd went from 40Mbps to 160+Mbps on the ethernet connection.
    Many thanks,
    AZ Cowboy
