gmarker
Mar 08, 2017Aspirant
Instructions on setting up WPA2 SSID on Netgear WNDER3400 Wireless Router on Mac Mini?
TheEther
Mar 08, 2017Guru
Here is a direct link to the section in the manual that deals with setting up Wi-Fi. Setting the WPA2 security option is a couple of pages past that point.
William10a
Mar 08, 2017Master
Did you mean the WNDR3400 and if so which version?
If the wndr3400 log into the router and go to wireless under wireless you find where you set ssid, passphrease, and security setting where you set for wpa 2 and save the changes here a link for the wndr3400v2 close the wndr3400v1 http://www.downloads.netgear.com/files/GDC/WNDR3400V2/WNDR3400v2_UM_EN.pdf
I hope that this helps the manual shows genie for setting up thr router genie is not needed just log in by 192.168.1.1 and user name and password to access the control gui of the router.
