Yahir
Nov 08, 2022Follower
Internet is not going to its max speed
My router is a R6120 and just updated to a higher megabyte speed. I am on 300Mbps and my router is only going 90Mbps. Also, I am using a wired connection. I have restarted the router from scratch, disconnected the router, and also tried turning it off and on but there are no changes in speed.
I was wondering if anyone could help me solve this problem and if so, please!!
1 Reply
Yahir wrote:
My router is a R6120 and just updated to a higher megabyte speed. I am on 300Mbps and my router is only going 90Mbps.Your new internet service is faster than your router.
According to Netgear's manual for this device, not always the most reliable source of information, the LAN and WAN ports support only 10BASE-T or 100BASE-TX. At 100 Mbps that makes it slower than many newer internet services and most modern network hardware.
Yahir wrote:
I was wondering if anyone could help me solve this problem and if so, please!!The only solution is to replace your router with one that supports Gigabit Ethernet.
The R6120 is pretty well the bottom of the Netgear range. The surprise is that it still sold this thing in2019. Gigabit Ethernet has been the standard for routers since around 2010. As you have discovered 100 Mbps is slower than many ISPs deliver.
