ccoltmanm
May 07, 2017Aspirant
Internet Just Stopped
I have a Zoom 5341J Cable Modem. I just bought an AC 1750 Nighthawk Netgear WiFi router. I hooked the router up to my modem last night, and all is well. This morning, after changing noth...
- May 08, 2017
Hi ccoltmanm,
1. What is the firmware version of the router?
2. Please do a factory reset after updating the router's firmware. Check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/9665
3. Try changing the Ethernet cable that is connecting the modem to the router.
4. You can also try doing a loop back test to check if the LAN/WAN ports are working. Check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/28408
Dexter
Community Team
William10a
May 07, 2017Master
How you updated the firmware on the router with the latest version?
