ccoltmanm
May 07, 2017Aspirant
Internet Just Stopped
I have a Zoom 5341J Cable Modem. I just bought an AC 1750 Nighthawk Netgear WiFi router. I hooked the router up to my modem last night, and all is well. This morning, after changing noth...
- May 08, 2017
Hi ccoltmanm,
1. What is the firmware version of the router?
2. Please do a factory reset after updating the router's firmware. Check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/9665
3. Try changing the Ethernet cable that is connecting the modem to the router.
4. You can also try doing a loop back test to check if the LAN/WAN ports are working. Check the link below for the steps.
http://kb.netgear.com/app/answers/detail/a_id/28408
Dexter
Community Team
DexterJB
May 15, 2017NETGEAR Moderator
Hi ccoltmanm,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
ccoltmanm
May 18, 2017Aspirant
Two days in a row, when I turned my ethernet connected PC on, the internet would drop completely from the router.
A few days have gone by, and the internet has not dropped anywhere.
