AliKDM's avatar
AliKDM
Internet LED not turning solid green
I recently tried setting up my NETGEAR Nighthawk AC1900. The install guide that came with it says after connecting the wires. It might take 10 minutes for the Internet LED light to turn solid green. Its been days and all it does is blink and shut off.
  • plemans's avatar
    You have the C7100v?
    Did you call your isp to have it activated?
    or go through the activation wizard?
    who's your isp?
    • AliKDM's avatar
      AliKDM
      No, I have the C7000. I tried to activate it with my ISP, but there saying the router modem needs to be turned on and running before they can activate it. The green Internet LED must be solid green before trying to activate it. I tried activating with Nighthawk app, even there saying the router modem appears offline.
      • plemans's avatar
        A couple things.
        1. the "internet" icon won't stay green until activated
        2. Does the power led stay solid green?
        3. do you have it connected to the coax entering the home? I know it sounds like a stupid question but I've regularly seen where people didn't have the coax connected properly or the coax runs through the home but is unhooked in a utility room
        4. If the isp can't see it, it might not be connected.
        5. if you connect a pc/laptop to it, (not app/wireless) are you able to log into the c7000?
