Allan1515
Aug 02, 2017Aspirant
Internet speed
PLEASE HELP! I have this R6220 netgear router with a dual band 2.4 ghz and 5 ghz. I have my iphones connected to my 5ghz band, and my ps3 connected to my 2.4 because it doesn't supports the 5ghz ban...
- Aug 15, 2017
Hi Allan1515,
1. What is the firmware version of the router?
2. Have you tried changing the wireless channel?
3. Does the issue persist on all the wireless devices that connect to the 2.4GHz band?
4. You can try using a WiFi analyzer to check for interference.
Dexter
Community Team
michaelkenward
Aug 03, 2017Guru - Experienced User
Wifi speeds are magic, not science.
5 GHz is faster than 2.4 GHz by design.
Then there is the geography of your wifi system and the different wifi bands you use. Are there neighbour who may have stuff that fights with your system?
What do people usually get with a ps3?
- Allan1515Aug 03, 2017AspirantI got neighbors but they are not really close enough to my house to interrupt my wifi.
- DexterJBAug 15, 2017NETGEAR Moderator
Hi Allan1515,
Dexter
Community Team
