GMAK's avatar
GMAK
iPhone router saturation
Environment:
WNDR4000 - V1.0.2.4_9.1.86
iPhone 6S - ????
I need some brief validation please. My wife's iPhone is saturating my router. I have looked for similar issues,
but can find nothing like. She connects the phone at night for its charging cycle. Unfortunately, I know very little
about these phones, but apparently, in addition to charging, the phone undergos some kind of data synchronization
for cloud backup purposes.
When this process get rolling, it will absolutely smoke this router. To the extent that simply initiating a web access
can be a 2-5 minute erratic operation. Of course, we've come to mortal combat over this issue. But I request a
validation of changes I've made, to ensure a proper circumvention.
Briefly, I changed the router configuration to enable QoS, and changed the iPhone traffic priority to low. I am test-
ing it now as this is written, and it seems to have dropped the phone traffic considerably. In fact, as I'm watching
the router activity, I see only very intermittent activity.
The previous iPhone(a 4S, as I recall), seemed to do this synchronization during charge, but didn't clog the net-
work nearly like this 6S does. I've been enduring this issue for at least a year, and just to busy/lazy to dig into
the problem.
Does my circumvention sound accurate, and will I(she) encounter other unintended problems with the phone
operation during network use?
Thanks.
    After not being able to find anything important in research of iphone backup
    settings, I did find this which describes my problem exactly
    http://hardforum.com/showthread.php?t=1737872
    My QoS recent change was not quite as fulfilling tonight as the last in the
    last few nights. I thought the QoS tweak had corrected the bandwidth
    problem. But, tonight's backup reared the saturation again. However it
    didn't seem quite as bad, and for a shorter duration.
    So I think the network saturation has been retarded, bu is still present,
    although to a lessor degree.
  • Retired_Member's avatar
    Retired_Member
    You never mentioned your UP load speed. What is it?
    • GMAK's avatar
      GMAK
      • Download Speed HELP 5.13 Mbps (641.6 KB/sec transfer rate)
      • Upload Speed HELP 0.69 Mbps (86.6 KB/sec transfer rate)
      • Latency HELP 43 ms
      • Jitter HELP 1 ms
      2.
      • Download Speed HELP 5.14 Mbps (642.1 KB/sec transfer rate)
      • Upload Speed HELP 0.69 Mbps (86 KB/sec transfer rate)
      • Jitter HELP 1 ms
      3.
      • Download Speed HELP 5.13 Mbps (641 KB/sec transfer rate)
      • Latency HELP 42 ms
      • Jitter HELP 1 ms
      4.
      • Download Speed HELP 5.12 Mbps (640 KB/sec transfer rate)
      • Upload Speed HELP 0.69 Mbps (86.8 KB/sec transfer rate)
      • Jitter HELP 1 ms
      This circuit is DSL, and the quickest offered for the DSL type. I know
      the DL speed is forecast as 6Mbps. But, I'm unsure of UL speed.
      This is ATT. I don't know what "jitter" is, but 43ms latency seems
      quite excessive to me. Although anemic, at least it's consistent.
      The reason for my concern is that the older phone produced no "hog-
      ging" at all. Then, the new phone rolled into town, and everything
      clogged up during these synchronization process(es). But, my change
      seems to have throttled the phone's network dominance. And, I've not
      had any complaints regarding other phone functions. So, it appears
      that all is well for the moment. I just wanted to verify that my change
      was the customary adjustment for my problem.
      Thanks.
        Retired_Member
        If anything is being saturated it's your ISP upload limit. Check the phone backup setup. I'm not familar with the iphone backup BUT I suspect it's doing a complete versa a partial backup which could explain why the new phone is causing a problem.
