Maxwel188884's avatar
Maxwel188884
Follower
Dec 24, 2020
Is my hardware hacked?
Thank you in advance for any help or insight. I was curious if this is what the inside of a c6300 is supposed to look like. I have been having a lot of issues with my network and the highlighted piece looks, odd to me. It looks crudely cut, the metal and wire soldering look amateurish.
Thank you all again for your time and help.
  • those are for the antenna. They're supposed to look like that.
    What issues are you having?
    do you have a screen snip of the cable connections page and the logs?
  • > [...] I have been having a lot of issues with my network [...]
       Thanks for that detailed problem description.
    > [...] It looks crudely cut, the metal and wire soldering look
    > amateurish.
       You're looking at normally invisible parts of a piece of
    cheap-Chinese plastic junk, not a finely crafted walnut desk.  If the
    wires are attached (to the antennas, I'd guess?), inside the box, then
    perhaps your concern is misplaced.
  • plemans's avatar
