GrannyShoes
Oct 19, 2015Follower
Is the N 600 WNDR 3400 Windows 10 compatible?
- Oct 19, 2015
The WNDR3400 predates Windows 10, but it should be compatible with respect to Wi-Fi and Ethernet support. The bundled Genie application may have some difficulty running on Windows 10, but it's optional and not really needed.
TheEther
Oct 19, 2015Guru
EdFitz
Nov 05, 2015Aspirant
I have the same question. My ethernet connection works, but I get a message about how the Net Genie application is not compatible with Win 10. Are there drivers or other software that update earlier Net Genie applications for WIn 10?
- ElaineMNov 06, 2015NETGEAR Employee Retired
EdFitzNETGEAR Genie application is not a mandatory software to make our routers work.
There have been reports that some users are having problems running NETGEAR Genie on Windows 10 and our engineers are investigating on this matter.
If you want to use NETGEAR Genie app, you may want to use an older utility version.
- EdFitzNov 11, 2015Aspirant
Thanks - your advice is indeed corrrect!
