Krishnakall1973's avatar
Nov 28, 2015
JNR1010v2 - Router does not connect to internet
Hello,   I have a 3 month old netgear wifi router, model number JNR1010v2. It was working fine until recently. It does not connect to the internet since the last two weeks. However, I am able to co...
  • Krishnakall1973's avatar
    Krishnakall1973
    Dec 07, 2015
    Elaine
    Thank you for your note. I did try the setup & much more. It has been confirmed that it is a hardware fault on the internet port in the router. I will be exchanging the router for a new one.
    Best Regards
    Krishna
