TwoTiny2's avatar
TwoTiny2
Lan To Lan Connections
Would someone please help.  I have a Netgear AC1900 Nighthawk Smart Wi-Fi Router as the primary router connected to a Netgear AC1200 Model R6100 Wi-Fi Router secondary router, connection is by Lan to Lan type connection.  What I need help with is, how do I gain access to the secondary router (Netgear AC1200 Model R6100 Wi-Fi Router)?  Any solutions would be greatly appreciated.
  • Retired_Member's avatar
    Retired_Member
    Aug 04, 2016
    it should take less than 10 minutes
    reset router 2 to defaults....leave it disconnected from network...use wired PC select AP Mode.....after reboot connect to router 1 lan to AP WAN.....login to main router and look at attached devices for AP IP address and or go to setup and use address reservations so AP gets same IP
    Retired_Member
    start over use AP Mode on 2nd router
    • TwoTiny2's avatar
      TwoTiny2
      Thank you, I sort of figure that was going to be the answer, but I was hoping there might be another way to do it.
        Retired_Member
