bt1527
Dec 17, 2021Aspirant
log in to router settings
I have a model 6400v2 AC1750. When I try to login to router settings I get this message: Router response timed out.I tried rebooting the router/reset router, nothing seems to work.
what are all the led's on the router showing? (color, blinking/solid)
Are devices working? (able to use internet)
What modem/gateway is it connected to?
are you trying to log in using its ip address or the default "routerlogin" address?
- bt1527AspirantEverything is working. During the updating the software I interrupted the process. I then tried to loin to the router. I get the message router response timed out
bt1527 wrote:
During the updating the software I interrupted the process.Uh oh. That way lies disaster.
What do the LEDs on the router look like?
Which of the various ways available are you using to login to the router?
Browser? (Which one?) App? (Which one?)
Which address?
- bt1527AspirantR6400v2
