RoaldOines
Jun 10, 2017Aspirant
Log shows internet connected (WAN side) to private network?
Yesterday's emailed log file shows that the WAN side connected to a private network IP address 22 times in the span of about eight minutes. Here's a portion of the log entries: [Internet connecte...
- Jun 28, 2017
Hi RoaldOines,
What I meant by bridge mode is disabling the DHCP/router functionality of the gateway and letting it function as modem only (will not give out a private IP [192.168.100.10]).
Dexter
Community Team
DexterJB
Jun 14, 2017NETGEAR Moderator
Hi RoaldOines,
1. What is the firmware version of the router?
2. What is the LAN IP that you have set for your network?
3. Is the router connected to a mode-router (gateway) or a stand-alone modem?
4. This is possibly during the boot up process only.
Dexter
Community Team
RoaldOines
Jun 15, 2017Aspirant
Hi Dexter,
Thanks for the reply.
The firmware version is V1.0.4.8_10.0.77; the LAN IP is 192.168.1.1 (subnet mask 255.255.255.0); the router's connected to a Cisco cable modem model DPC3216 with an IP of 192.168.100.1 (noting the repeated internet connects in the log to 192.168.100.10).
When you say that it's possible only during the boot up process, are you referring to the cable modem's boot up or the R6300v2's boot up?
And this brings to mind something I've been wondering about for a while now: The R6300v2's logs used to attempt to identify the type of "attack" but now where the type used to be it just says "(null)" and gives a large negative integer, for example:
[DoS attack: (null)] (-1085517592) attack packets in last 20 sec from ip [192.168.1.199], Tuesday, Jun 06,2017 11:22:18 (most times the offending IP is not a non-routable one, but I assume those can be faked).
It's like there's a translation table missing in the firmware...
