RoaldOines
Jun 10, 2017Aspirant
Log shows internet connected (WAN side) to private network?
Yesterday's emailed log file shows that the WAN side connected to a private network IP address 22 times in the span of about eight minutes. Here's a portion of the log entries: [Internet connecte...
- Jun 28, 2017
Hi RoaldOines,
What I meant by bridge mode is disabling the DHCP/router functionality of the gateway and letting it function as modem only (will not give out a private IP [192.168.100.10]).
Dexter
Community Team
DexterJB
Jun 14, 2017NETGEAR Moderator
Hi RoaldOines,
1. What is the firmware version of the router?
2. What is the LAN IP that you have set for your network?
3. Is the router connected to a mode-router (gateway) or a stand-alone modem?
4. This is possibly during the boot up process only.
Dexter
Community Team
DexterJB
Jun 27, 2017NETGEAR Moderator
Hi RoaldOines,
I am referring to the boot up of the R6300v2. Does this behavior persist if you have the gateway set to bridge mode?
Dexter
Community Team
- RoaldOinesJun 27, 2017Aspirant
Hi Dexter,
Thanks for the reply. Actually I haven't seen that original behavior (the R6300v2 connecting to the non-routable address on the WAN side) since that one time, so it hasn't persisted. And sorry, I don't know what "bridge mode" is.
- DexterJBJun 28, 2017NETGEAR Moderator
Hi RoaldOines,
Dexter
Community Team
- RoaldOinesJun 29, 2017Aspirant
Oh. I don't have the credentials needed to change settings on the Cisco cable modem and "bridge mode" wasn't one of the properties I can see.
