GrubLeo's avatar
GrubLeo
Login refused by R6400V2 after firmware upgrade.
Hi all,
this is not a new one, I think.
After updgrading to 1.0.4.128 I can't log into the router (connection refused by router: tried ip address and www.routerlogin.net and several browsers).
Resetting (power and button) didn't help. Internet connection is good (wired and wireless). Nighthawk app on the phone works fine and has access.
Searched the net for help and tried all the  bells and wistles.
Tried downgrading with tftp and the windows app but both failed.
At least 3 things are different in my case:
1. The R6400 lights behave different then described on the Netgear site (nothing flashing unless I missed pushing some undocumented button).
2.My router takes care of dhcp and I can't change that (so setting static IP was not possible).
3. Finally my zenbook has no RJ45  but uses a USB2Gigabit converter.
I guess I should be lucky that my phone can still ask my router to check for updates.
But for now I am done. Seems to be that some ports are not opened (has happend before?)
If any of you has some other suggestions feel free to share.
