Dave_Nelson
Jun 14, 2016Tutor
Manually updating firmware - asked often but threads closed
I have a WNDR4500 I received from a friend. The green power light blinks continiously which tells me that the firmware is corrupt. I know this question has been asked many times before but I am stuck...
- Jun 14, 2016
The IP address and subnet mask you picked are not good choices. Try the following:
IP Address: 192.168.1.2
Subnet Mask: 255.255.255.0
Router: 192.168.1.1
Then retry step 4.
Anonymous
Jun 14, 2016I dont' own a Mac but, I would think you could enter a static IP in the network card setup. The router cannot issue an IP if DHCP is not working so if you cannot set a IP in the MAC you're hosed.
That router is a lemon hands down give it back and buy a working one.
- Dave_NelsonJun 14, 2016Tutor
I would think that the IP address of the router is hard coded into the router. My Mac can see it as connected but for the life of me I can't figure out how to determine the IP address of what it sees. As far as giving it back, I knew it wasn't working when he gave it to me but I wanted to take the challenge to see if I could fix it. If I can't fix it, it goes into the trash. While working on the problem I realized that the router was going to be a problem based on the number of support topics I found on this site on that model. I'm open to suggestions regarding a reliable model.
- doraemonJun 14, 2016Prodigy
Assign static through System Preference > Network > TCP/P > Configure IPv4 should set to Manually and type in your IP address
Make sure that the Router address is the default IP of the router (192.168.1.1).
Thanks doraemon. That gave me some progress but I'm still missing something. I wasn't sure what valid IP numbers are for my computer so I set them as follows
I tried pinging 192.168.1.1 but that fails. Regardless, I tried uploading the file to the router. When I reboot the router and wait until a light indicates I'm connected but the routher system bootup light is still solid orange, I get the following error:
If I wait until the system light turns to a flashing green, I get the following error
The password I'm using is 'password'
Many thanks for your help! I hope this thread will give detailed steps for Mac users having problems with other models as the Netgear help missess details.
