Dave_Nelson
Jun 14, 2016Tutor
Manually updating firmware - asked often but threads closed
I have a WNDR4500 I received from a friend. The green power light blinks continiously which tells me that the firmware is corrupt. I know this question has been asked many times before but I am stuck...
- Jun 14, 2016
The IP address and subnet mask you picked are not good choices. Try the following:
IP Address: 192.168.1.2
Subnet Mask: 255.255.255.0
Router: 192.168.1.1
Then retry step 4.
Retired_Member
Jun 14, 2016I dont' own a Mac but, I would think you could enter a static IP in the network card setup. The router cannot issue an IP if DHCP is not working so if you cannot set a IP in the MAC you're hosed.
That router is a lemon hands down give it back and buy a working one.
Dave_Nelson
Jun 14, 2016Tutor
I would think that the IP address of the router is hard coded into the router. My Mac can see it as connected but for the life of me I can't figure out how to determine the IP address of what it sees. As far as giving it back, I knew it wasn't working when he gave it to me but I wanted to take the challenge to see if I could fix it. If I can't fix it, it goes into the trash. While working on the problem I realized that the router was going to be a problem based on the number of support topics I found on this site on that model. I'm open to suggestions regarding a reliable model.
