Warren57's avatar
Warren57
Metal building wifi
Another remote metal building question.
i live on an acreage. Added a wavlink extender to my network at the house. Works good everywhere across the acreage, good signal, except wifi signal inside metal building is bad. Great outside the building but can’t get through the steel.
so I have an older netgear ac1600 extender that I decided I would put inside the metal shop building. It gets some signal but not great. So I realize the antennas can only pick up signal that’s in the building.
my question, can I take the antennas off and mount them outside and connect with cables? We are talking 1’ or less. NETGEAR extender on inside wall and antennas on outside. That way I would get the good wifi signal from outside and send it through the building.
if this makes sense what cable, fittings, etc would I need?
or is there a simpler way to accomplish my goal?
thanks
warren
  • CrimpOn's avatar
    CrimpOn
    Since you are familiar with Wavlink, that would seem to be a reasonable choice.
  • CrimpOn's avatar
    CrimpOn
    Thanks for the model number.   I see some factors to consider:
    • To get a communications inside the metal building, the WiFi antennas must be outside (or inside placed next to a non-metal part of the wall.  i.e. cut a hole and glue a piece of plastic over it.)
    • If there is a need to have WiFi service inside the building, then there must be WiFi antennas inside.
    • The EX6200 has only one set of antennas.  They cannot be in both locations at the same time.
    • Getting power to a unit outside the building is not trivial.
    What about this:
    • Purchase an outdoor rated WiFi extender which is powered by Power over Ethernet (PoE).  The extender goes outside and the Ethernet cable comes inside and connects to the PoE power supply, and then connects to the EX6200.
    • Set up the EX6200 in Access Point mode (page 21 of the User Manual)
    • Warren57's avatar
      Warren57
      I have an AX3000 wavlink extender at the house now that is getting my signal to that areas outside.
    • Warren57's avatar
      Warren57
      So an outside extender will pick up the wifi signal on the outside and the Ethernet cable will take that signal to the ex6200? If I understand correctly, that would be a great option. Can you offer advice on what outside extender I might consider?
      sorry I don’t know to much about this, I’m a 75 year old newbie ….ha ha
  • Oh, forgot, running an Ethernet cable would be costly with concrete and asphalt between house and shop
  • plemans's avatar
    No. But you could always do 2 extenders.
    Put one exterior and run an ethernet cable from that interior to the other extender that you'd put inside.
    Or depending on the distance and budget, do it right and get a point to point system that you'd mount on the house and another you'd mount on the metal building. Then you'd run an ethernet cable from the one on the metal building interior and put your access point/extender in there.
    • Warren57's avatar
      Warren57
      I have a wave link extender at the house which has a strong signal outside the metal building. But the NETGEAR extender is on the inside of the building so it can’t get the signal, if I move the NETGEAR outside or open the door there’s a strong signal.
      i need a way to get the signal into the building
  • CrimpOn's avatar
    CrimpOn
    What is the actual  model number?  (from the product label.  AC1600 is a marketing term regarding the maximum 'speed')
    Is there a window facing the main building?
    • Warren57's avatar
      Warren57
      Tried texting one of the antennas from the NETGEAR extender to the outside and that helped on the 5gh signal, but did nothing for the 2.4gh signal
