SiyonKart
Aug 18, 2021Follower
MK62 Question
Hey guys. Having some poor signal throughout the house with a single router setup. My question is since I already have a nighthawk router that I want to continue using, can I use the MK62 router as...
Aug 18, 2021Guru - Experienced User
the mesh networks like the MK or the Orbi system need a controlling mesh router.
so you wouldn't be able to "integrate" the mk into your system but you could keep your router and use it as backup or to offload the mesh network.
