Reith's avatar
Reith
Apprentice
Mar 20, 2021
Mobile devices keeps losing wifi connection
I currently have a Orbi router RBR50 Model. I have been rebooting the router for the last week. Because my tablets and cell phones keeps losing wifi.
But any devices directly connected to a satellite via Ethernet still streams.
What could be causing this??
I have had this device since 2018
Thank you in advance
  • Me too - After applying the firmware update to v2.6.2.104 - our cell phones (1 Samsung and multiple iphones), stopped connecting.  However, our Rokus stay connected.  have to reboot the router 3 times daily to reconnect phones.  Anybody have a fix for this or having similar issues with the firmware?
  • I also am having the same problem.  A couple times a day we have to go in and reboot the Orbi to restore connectivity to our Wi-Fi devices.   If we have a device that is currently streaming, it usually continues to stream, but other devices drop connectivity.
    This is also on firmware version 2.6.2.104
  • Me too! Router and satellites are not even 2.5 years old. Could it have something to do with the time change?
  • Go into NTP settings. change DST from Netgear to manual and type time.nist.gov This should resolve the wifi lose issue. Give it 12-24 hours to see if it works and repost here your status. Thank you Have a nice day
      • Reith's avatar
        Reith
        Apprentice
        See attached PDF screenshot
    • Thanks for the screenshots Reith  - I'me input time.nist.gov - does this require a reboot after I click apply to the settings
      • Reith's avatar
        Reith
        Apprentice
        No reboot needed after applying settings
    • Froo's avatar
      Froo
      Tutor
      Unfortunately I'm still having the problem. I should clarify that my actual problem is the reverse of the one in the subject line on this thread. I lose connection to the wifi on most of my computers but seem to keep it on my phones. This is still happening three times a day: before 6AM, ~7PM, ~10PM
      • Reith's avatar
        Reith
        Apprentice
        Did you go into the NTP setting and change the DST? Also have you checked and see if there is a new firmware to update?
  • I applied the recommended fixes, with the nist.gov website & We have not had to reboot since.
    • Froo's avatar
      Froo
      Tutor
      I've not had to reboot for over 24 hours. Fingers crossed the NTP settings change did the trick!
