mamabear15
Mar 13, 2018Follower
Model and Router not connecting cm400 and R6080
Just moved into a new apartment. Misheard the lady and I bought just a router, and it ended up being that I needed both a router and a modem. Went back and bought a modem to go with the router. They're both Netgear products. I was told they would work together even if I didn't purchase them as a set. Now I can't get them to connect. The modem works fine, if I plug it directly into my laptop there aren't issues. When it's connected to the router, however, through ethernet cable they cannot connect. Please help...?
Hi mamabear15,
1. Please make sure you go through the setup procedure. The link below may help out.
http://kb.netgear.com/app/answers/detail/a_id/22697
2. You may also try MAC spoofing. The steps are linked below.
http://kb.netgear.com/app/answers/detail/a_id/1086
Dexter
Community Team
- DexterJBNETGEAR Moderator
Hi mamabear15,
Dexter
Community Team
Hi mamabear15,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
