FlintFenton's avatar
FlintFenton
Modem 200Mbps, Router 35Mbps
Spectrum just upgraded my internet speed to 200Mbps but I can only get 36Mbps the the router.  I hardwired my pc directly to the modem and got 220Mpbs.  Any suggestions on how to get more speed thru my router would be appreciated.
1 Reply
  • plemans's avatar
    What router do you have?
    what firmware is on it?
    What modem is it connected to?
    Did you try a factory reset and install on the router? (don't reinstall using a backup configuration)
