frmrbn
Oct 26, 2022Follower
Modem/Router to 2 Routers, One Green Light, One Amber No Data
I'm networking multiple homes on a rural property. I have a C7000v2 as the modem. Router 1 and Router 2 are both AC1200. A month ago the whole system was working great. The connection between mo...
michaelkenward
Oct 27, 2022Guru - Experienced User
frmrbn wrote:
I have done all the standard reboots/factor resets, change ports etc.
Remember, a reset puts the router back into its default state. A router is a router.
As plemans suggests, that is not usually the best way to run two routers on a network.
What is Double NAT? | Answer | NETGEAR Support
and
How to fix issues with Double NAT | Answer | NETGEAR Support
