Chris_1000_Oaks's avatar
Apr 30, 2021
moving from a house with fiber to the premises and need to connect my Orbi RBR50
I am moving house and at present I have Fiber to the premises and connect my Orbi RBR50 to an Openreach modem. In my new house. I am told that when the line is reconnected I should have a master socket so will need a modem to plug my router into. PlusNet are sending me a basic Hub1 modem/router but I dont think they are the best around and would like to buy a better modem.
Can anyone suggest the best option for me to connect my RBR50
  • antinode's avatar
    antinode
    May 04, 2021
    > [...] Plusnet Hub1 router modem [...]
       At last, something like a model number.
    > [...] the DSL port.
       With a DSL connection.  Whew.
    > [...] I really need the Mesh network my Orbi provides for greater
    > coverage.
       I got that.  Which takes us back to my first response.
       My quick Web search didn't find much on the Plusnet Hub1, so it's not
    obvious to me whether it has a modem-only ("bridge") mode.  If not, or
    if you can't find it, then, as previousy suggested, "configure the RBR50
    as a wireless access point".
    > When I try to search for a modem I get lots of router modems, [...]
       With my weak psychic powers, I have no idea for what you might have
    searched, or what you might have found.
    > [...] so was hoping to find the best modem [...]
    > [...] I'd avoid any Netgear DSL modem products.
       Still true.
    > [...] that supports supports dual-band Wi-Fi fast enough not to limit
    > the Orbi
       I don't know what speed your ISP promises, but I would expect a DSL
    connection using any modem to be the bottleneck in your network.
  • > [...] connect my Orbi RBR50 to an Openreach modem. [...]
       That tells me approximately nothing about that "modem", or how it
    might have been configured.
       RBR50[v1] or RBR50v2?  Look for "Model" on the product label.
    Firmware version?
    > [...] I am told that when the line is reconnected I should have a
    > master socket [...]
       I don't know what that means.
    > [...] so will need a modem to plug my router into. [...]
       Again, a description which conveys no useful information.
    > [...] PlusNet are sending me a basic Hub1 modem/router but I dont
       Are you worried about the _modem_ in that modem+router, or about its
    _router_?
       Not I.  Not without knowing something about the gizmo to which you'd
    be connecting it.
       If the "a basic Hub1 modem/router" has a modem-only ("bridge") mode,
    then I'd guess that you'd be able to configure it that way, and use the
    RBR50 as a router (as, I assume, you had been doing with your
    (unspecified) "an Openreach modem").
       If the router section of the "a basic Hub1 modem/router" can't be
    disabled/bypassed, then it should be possible to configure the RBR50 as
    a wireless access point, and use the "a basic Hub1 modem/router" as your
    router.
       Visit http://netgear.com/support , put in your (actual) model number,
    and look for Documentation.  Get the User Manual (at least).  Read.
    Look for "Use the router as a WiFi access point".
          https://kb.netgear.com/26765
    • Chris_1000_Oaks's avatar
      Chris_1000_Oaks
      Hi, I should have added that I am in the UK. Here, Internet connectivity to houses is provided by Openreach, formerly a part of British Telecom, but now it's own entity now, as it not only has BT as a customer but all the other ISP's providing service in the UK.
      They have now upgraded most connections to UK properties to "Fiber to the Cabinet" which serves several properties in a small area and the final stretch to the property is by copper wire.  They are geradually trying to upgrade this so that the connection is by fiber direct to each property but the roll out is slow. We were lucky to have this direct fiber connection at my present house and this terminates in a box on the wall owned by Openreach and not configurable by the house occupants. This is basically a modem and I have my Orbi plugged into this.
      At my new house I have what is a conventional phone line , as I said connected by copper wire from the nearest telegraph pole and where this ccomes into the house there is a telephone socket. The one the external wire goes into is called the a Master Socket and there are usually other extenssions around the house. However it is reccomended you plug your modem/router into this Master Socket rather than one of the extensions. However my Orbi RBR50 does not have a modem in it, so this is my query, My ISP, PlusNet have provided me with their basic modem/router which should work and I think I can plug my Orbi into that with my satelite RBS50 in another part of the house to set up a mesh network.
      This is perhaps where my knowledge of such things falters as I am not sure what I am doing. I have read I can turn off the wifi on a router modem but think there is no switch on the Plusnet one so it has to be disabled (not sure how).
      My thought was that I could buy what is equivelent to the Openreach box, a simple modem which allows me to plug in my Orbi in and it ould function as it does now, albeit slightly slower, not being on a dedication fiber connection.
        Chris_1000_Oaks
        I meant to add I will check out the links mentioned to see if that helps though really would like a buy off the shelf solution if possible
