Retired_Member's avatar
Retired_Member
Feb 10, 2016
Multiple DDoS Attacks + Internet Freezing Every 30 Seconds
I am getting anywhere from 3-10 ddos attacks per day, multiple of them coming from the same IP, and it's happening every day, and it's really annoying. I've tried installing some free VPNs and DDoS p...
  • ElaineM's avatar
    ElaineM
    Feb 23, 2016
    Are you running wired or wireless?
    If you bypass the router, will you get the same ping spikes?
