Retired_Member
Feb 10, 2016Multiple DDoS Attacks + Internet Freezing Every 30 Seconds
I am getting anywhere from 3-10 ddos attacks per day, multiple of them coming from the same IP, and it's happening every day, and it's really annoying. I've tried installing some free VPNs and DDoS p...
- Feb 23, 2016
Are you running wired or wireless?
If you bypass the router, will you get the same ping spikes?
Retired_Member
Feb 22, 2016I did that a few weeks ago, and it didn't help, but I deleted my old skype and started off with a fresh one without so many contacts. I'm only getting one DDoS every 2-3 days which is a lot better, especially since they strike when I'm not using my PC, but that issue is done. But I'm still getting really bad ping spikes, and they're even worse than before.
ElaineM
Feb 23, 2016NETGEAR Employee Retired
- Retired_MemberFeb 25, 2016
Running wireless, and ethernet has not helped.
- ElaineMFeb 26, 2016NETGEAR Employee Retired
If the router is out of the picture will you get the same ping spikes?
What's the brand of the modem?
- Retired_MemberMar 03, 2016
Yes, I do. The brand is Arris.
