Denbers
May 03, 2020Tutor
My AC1200 EX6110 when I try to connect to it says i am entering the incorrect password. It does conn
to reset you have to push and hold the reset button for 7-15 seconds. it shouldn't auto-reconnect if it was fully reset
What router are you connecting to?
Try factory resetting the extender and re-running install using the installation wizard and not wps.
