leefoo's avatar
leefoo
My password for my router no longer works
Somehow my Extender WiFi got dropped. I can access only my initial WiFi now. When I try to access "&&&&&_EXT" and I put in my correct password, it doesn't work anymore. How can I reset the passwor...
  • michaelkenward's avatar
    michaelkenward
    May 10, 2017
    If it is an iThing that is causing problems, then that is the first place to look. An upgrade to iOS will have no effect on the WN1000RP, it certainly will not change the wifi password.
    If you are trying to connect to the wifi, then tell your iThing to forget past connections to "&&&&&_EXT" and start from scratch.
    You can find a detailed manual for the WN1000RP here:
    >>> WN1000RP | Product | Support | NETGEAR <<<
    If nothing works, then you can reset the WN1000RP to its factory defaults. See page 7 of the manual.
