Elliesne's avatar
Elliesne
My phone can’t connect to the R6020-router
Hi! I bought my router back in 2019 and used it for about two months and haven’t used it since. Now I wanna use in my new apartment but can’t get it to connect to my phone despite all the symbols being green. I’ve restarted the router several times and I still can’t get it to connect to my phone. I have an iPhone xs and I’ve tried to enable local network access but the app can’t be seen in the WiFi-privacy settings, so I can’t manually enable it. It’s been driving me crazy and I don’t know what else to do, can someone please help me??
  • michaelkenward's avatar
    michaelkenward
    Your router does not connect to the phone. It is the other way round. You have got it right in your subject.
    The router broadcasts a wifi signal and your phone connects to that.
    If you are using an iPhone, this might be useful:
    NETGEAR Mobile Applications and Apple Devices FAQ - NETGEAR Communities
    Are you trying to use the Nighthawk App to set up your router? It can be a lot easier of you do that with a web browser and the graphical user interface (GUI) and a wired connection from a PC to the router.
    • Elliesne's avatar
      Elliesne
      Thanks for the info! I’ve tried to find the feature where I can enable it manually according to the manual you linked but my phone can’t find the router and the wifiname isn’t in the list of wifis so I can’t manually enable the private IP-address. And I don’t have the ability to do it through my computer so I have to do it through the app. Do you think it matters I’ve set it up once before or is my phone the only issue?
        michaelkenward
        What modem/ONT/gateway sits between your R6020 router and the internet?
        Does it also produce wifi?
        Do you have a PC? Can you plug it into the router?
        Did you find the section in the manual?
        Manually Set Up the Internet Connection
        I don't understand that. What is this private IP-address? You don't need to do that to connect your router to the Internet through a modem.
        Did you read the link to the iOS information?
        This has nothing to do with its IP address.
        The router has a label on the back with the default SSID and password for the wifi. It if then down to your mobile to connect to that. If it can't, then you have a problem with your mobile device, not the router.
        One thing you can try if you can't see the wifi is to reset the router.
        How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
