bfields
Apr 15, 2021Aspirant
My router/modem won't connect to internet
Laptop will connect to wireless but will not connect to internet?
Can wired devices connect to the internet?
what have you tried doing to fix it? (reboot, factory reset, etc)
- bfieldsAspirantFactory reset worked but now the upstream light is orange??
If you log into it, you can view the cable connections page. Take a screen snip of that and post it back here. It shows things like upstream/downstrea/snr, etc
That helps check the connection
