psuro's avatar
psuro
Tutor
Jul 11, 2022
N150 - WNR1000 v.3
I've had my router since forever, brand new. I always had it set up for ethernet and deactivated wifi. I now have devices in my home that have no ethernet capabilities and have to set my router for wifi capabilities. However the login page , http://routerlogin.net or .com no longer exists. It reroutes to a different login page on netgear's web site and my router is not an option. Does anyone know a workaround for this so I can re-activate the wifi setting on my router? Any help will be greatly appreciated!
  • My son figured it out!!! Somehow we had switched the ethernet cables around and the cable from the modem to the router was plugged into an ethernet port. Plus he found a wifi button to push and hold on top of the router! Voila! I should have known it was something simple plus he's been a tech wiz since he was only 2 years old!
    Thank you for all your responses and time. God bless you 100 fold in Jesus Name!
  • plemans's avatar
    You can use its ip address.
    The default is usually either 192.168.1.1 or 192.168.0.1
    Sometimes it'll be 10.0.0.1 if you're in a double nat.
    • psuro's avatar
      psuro
      Tutor
      I already tried using the first IP address many times today but the connection times out. And I tried your alternate IP's and they both time out also. Thanks for responding though, I appreciate your time and consideration. God bless you!
  • plemans's avatar
    Might look at upgrading in the future. Thats a pretty slow/base model device. Unless you're on some pretty slow dsl, you'll see a significant improvement in speeds with an upgrade to even a fairly basic gigabit dual band router.
